title: ETC NYC First Mondays - May 2025
description: "Join us at ETC's New York outpost for a monthly events series. This month: a panel discussion with the lighting team of Dungeons & Dragons: The Twenty-Sided Tavern"
image: https://info.etcconnect.com/hubfs/header_20sided_chicklet-1.png
[![EtCetera\_319x104](https://info.etcconnect.com/hs-fs/hubfs/EtCetera_319x104.png?width=319&height=104&name=EtCetera_319x104.png "EtCetera_319x104")](https://blog.etcconnect.com?hsLang=en)
<https://info.etcconnect.com/etc-nyc-first-mondays-2025-may5#gwen-offcanvas-primary>
[![ETC Blog](https://info.etcconnect.com/hs-fs/hubfs/EtCetera_319x104.png?width=319&height=104&name=EtCetera_319x104.png "ETC Blog")](https://blog.etcconnect.com?hsLang=en)
- [SPOTLIGHT](https://info.etcconnect.com/tag/spotlight)
- [ETC CULTURE](https://info.etcconnect.com/tag/etc-culture)
- [GEAR](https://info.etcconnect.com/tag/gear)
- [LEARN](https://info.etcconnect.com/tag/learn)
- [ODDS & ENDS](https://info.etcconnect.com/tag/odds-ends)
- [BRIGHT IDEAS](https://info.etcconnect.com/tag/bright-ideas)
Search
## [![blog-header](https://info.etcconnect.com/hs-fs/hubfs/blog-header.png?width=476&height=155&name=blog-header.png "blog-header")](https://www.etcconnect.com)
[✕](https://info.etcconnect.com/etc-nyc-first-mondays-2025-may5#gwen-offcanvas-primary)
![header\_20sided](https://info.etcconnect.com/hubfs/header_20sided.png "header_20sided")
The ETC NYC First Mondays events series brings production professionals together to socialize and share knowledge.
How do you design and program a show that's different every night?
Join the design team of the innovative and interactive show [Dungeons & Dragons: The Twenty-Sided Tavern - Lighting Designer Mike Wood, Associate LD Abby May, and Programmer Henry Wilen - as they talk about](https://thetwentysidedtavern.com/) how they approached a show that reprograms itself every night.
The panel discussion will be preceded and followed by a reception where you can mingle with the panelists, ETC staff, and your fellow lighting professionals.
Haven't seen [Dungeons & Dragons: The Twenty-Sided Tavern?](https://thetwentysidedtavern.com/)
\*Use special discount code ETC30 for 30% off shows from May 1-6\*
#### **WHEN:**
#### **Monday, May 5th, 2025**
**Doors and reception at 6pm**
**Talk begins at 7pm**
#### **WHERE:**
#### **ETC NYC**
#### 630 9th Avenue, Suite 1001
#### New York, NY 10036
## Yes, I'm coming!
![logo-footer](https://info.etcconnect.com/hubfs/Logos%20-%20Icons%20-%20Design%20Elements/logo-footer.png "logo-footer")
visual environment technologies
![ETC blog](https://info.etcconnect.com/hubfs/ETC-logo_footer-wh.png)
  <https://blog.etcconnect.com/?hsLang=en>
