title: Emergency Lighting Design Guide
description: Emergency Lighting made simple! The ETC Emergency Lighting Design Guide explains the concepts and gear you need to meet code and keep people safe.
image: https://info.etcconnect.com/hubfs/Emergency_Lighting_Design_Guide_Cover800.jpg
[![EtCetera\_319x104](https://info.etcconnect.com/hs-fs/hubfs/EtCetera_319x104.png?width=319&height=104&name=EtCetera_319x104.png "EtCetera_319x104")](https://blog.etcconnect.com?hsLang=en)
<https://info.etcconnect.com/emergencylightingdesignguide#gwen-offcanvas-primary>
[![ETC Blog](https://info.etcconnect.com/hs-fs/hubfs/EtCetera_319x104.png?width=319&height=104&name=EtCetera_319x104.png "ETC Blog")](https://blog.etcconnect.com?hsLang=en)
- [SPOTLIGHT](https://info.etcconnect.com/tag/spotlight)
- [ETC CULTURE](https://info.etcconnect.com/tag/etc-culture)
- [GEAR](https://info.etcconnect.com/tag/gear)
- [LEARN](https://info.etcconnect.com/tag/learn)
- [ODDS & ENDS](https://info.etcconnect.com/tag/odds-ends)
- [BRIGHT IDEAS](https://info.etcconnect.com/tag/bright-ideas)
Search
## [![blog-header](https://info.etcconnect.com/hs-fs/hubfs/blog-header.png?width=476&height=155&name=blog-header.png "blog-header")](https://www.etcconnect.com)
[✕](https://info.etcconnect.com/emergencylightingdesignguide#gwen-offcanvas-primary)
# Have confidence in your emergency lighting system
ETC’s Emergency Lighting Design Guide makes the concepts, code, and construction of an emergency system comprehensible.
The guide offers a top-down explanation of the logic of emergency power systems and controls, code references, and real-world examples to help you design safe and robust emergency systems for the U.S. market.
![Emergency\_Lighting\_Design\_Guide\_Cover800](https://info.etcconnect.com/hs-fs/hubfs/Emergency_Lighting_Design_Guide_Cover800.jpg?width=400&height=400&name=Emergency_Lighting_Design_Guide_Cover800.jpg "Emergency_Lighting_Design_Guide_Cover800")
![ETC blog](https://info.etcconnect.com/hubfs/ETC-logo_footer-wh.png)
  <https://blog.etcconnect.com/?hsLang=en>
